Recharging the A/C on an f-body (93). Need some help.
Old Jul 10, 2006 | 04:59 PM
  #16
Dave89IROC's Avatar
Re: Recharging the A/C on an f-body (93). Need some help.
Originally Posted by Ace_437
The hose only fits on one of the schrader valves. The other is too large.
yup
the ports are different sizes, just to make sure they cannot be hooked up backwards
Old Jul 11, 2006 | 10:28 PM
  #17
Ace_437's Avatar
So I pulled the ECM/BATT fuse and tested it out. Still hot as **** air. Maybe I'll go back out there with the pressure gauge and test it again. It might be empty if the compressor wasn't running when I tried filling it I guess. It did sound a little different when I turned the air on though. I don't remember hearing that awhile ago when I was messing with it.
Old Jul 12, 2006 | 12:15 AM
  #18
dubbsix's Avatar
I am having the same problem with my 93. Before my compressor would cycle on and off but now i cant get the damn thing to turn on. I tried pulling the pcm bat fuse, but i havent tried just disconnecting the battery. Im gonna try disconnecting the battery, new a/c compressor relay and see if i can revive it that way.
Of course there is still the matter of a possible bad low pressure switch!
Old Jul 12, 2006 | 01:41 PM
  #19
"White Knight"'s Avatar
I don't know why people try to diagnoise these A/c problems without guages
Old Jul 12, 2006 | 03:56 PM
  #20
Ace_437's Avatar
I still can't get the ****ing thing to put out cold air. Oh, and I do have a gauge. Pressure should be perfect (if the compressor is even running, but I can't honestly tell).
Old Jul 12, 2006 | 08:14 PM
  #21
Mtrhds94Z's Avatar
To do it 'right', you need a set of gauges[for both the 'low' and 'high' sides of the system] Harbor Freight has a cheap set for about $50 that works OK..
It appears that you have the single [low side] gauge that comes in the 'kit' with a can of freon?
While better than NO gauge at all, it still doesn't really do the job right..
Old Jul 12, 2006 | 08:34 PM
  #22
Temple's Avatar
Ace 437
42,000 miles on a '93....you better start driving that car
Old Jul 12, 2006 | 08:44 PM
  #23
Ace_437's Avatar
Originally Posted by Temple
Ace 437
Nope. Don't want to put too many miles on it. I'm actually trying to sell it, slowly.
Old Jul 13, 2006 | 01:43 PM
  #24
does it measure both high and lowside pressures, because if you look in my original post I say "gauges" as in two. If it does then give us the readings and we will be able to tell you more. But it sounds like you don't need any help.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
n2oblkz
Oct 12, 2015 01:53 AM
surreybrad
Sep 29, 2015 09:00 PM
