Rear gear question
Old Apr 2, 2006 | 07:59 AM
chas's Avatar
Rear gear question
Just wanted to know what rear gear i have, its a 97 Camaro Z-28 ss with a auto tranny. Is it a 3.23 rear? When i'm doing 30mph the rpms are about 900!
Chas
Old Apr 2, 2006 | 11:43 AM
race u 2's Avatar
Re: Rear gear question
i think this is the right #'s for you if in your glove box has the list of options from the factory code #'s if you have a GU2 = 2.73, GU4 = 3.08, GU5 = 3.23 & GU6 = 3.42 ALSO IF THERE IS A G80 = LIMMITED SLIP REAREND
Old Apr 2, 2006 | 03:24 PM
chas's Avatar
Thanks!
It says GU2, but the sticker is on the door jam.
I'm guessing the rear gear is still stock, if i give the car about 70% gas, the back end wants to go sideways! Sure seems the car has alot of power for a 2:73 gear.
Chas
Old Apr 2, 2006 | 04:15 PM
2001NBMZ28's Avatar
If you want to double check it go to www.f-body.org/gears/ You never know, my door says GU2 but I put 3.42's in it. Check it on the highway, 30 MPH is too slow - my TC doesn't even lock until about 42.
Old Apr 2, 2006 | 06:42 PM
urbaNHunter44's Avatar
Go 70 mph, and hold the tranny in 3rd gear (your 1:1 gear). Check your RPMs. If you're taching 2730, then you have 2.73s, if you're taching 3230, then you have 3.23s. It's that simple.
ChrisFrez
Dec 21, 2014 09:47 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
ChrisFrez
Dec 15, 2014 03:09 PM
Jul 4, 2005 05:00 PM
