rap module short
Old Jun 5, 2005 | 02:35 AM
94307's Avatar
rap module short
My car has blown two rap modules and after further checking, it appears circiut 75 (connector B) has a short to ground and I want to know if it goes anywhere other than the fuse panel. Is there anyplace in the wiring that would cause a short like a sharp piece of metal, etc? It would be really nice to know exactly where that wire runs from the rap module to the fuse panel.
Chuck
Old Jun 5, 2005 | 06:01 AM
slopokrodrigez's Avatar
Re: rap module short
Circuit 75 on the dark blue wire goes from the I/P fuse panel through the large 48 pin connector (c200) located by the LH kick panel and then onto the RAP.
However, if that circuit had a short to ground, it would blow the radio fuse #17 (15amp) and it would blow the power accy fuse #7 (15amp). These 2 fuses would blow before any damage could be done to the 2 internal relays in the RAP. It would appear that a short on that line would not damage the RAP.
You didn't mention the fuses, how did you conclude that line was shorted to ground?
Old Jun 6, 2005 | 06:15 AM
94307's Avatar
fuses never blew. I used an ohm meter to check resistance to ground, and it was 0.1 ohms. This is with the rap module disconnected. I woule not think the fuses would blow if the short was before them. The rap module seemed to act as a fuse when it blew.
Old Jun 9, 2005 | 07:21 AM
94307's Avatar
Would someone check the resistance to ground of the blue wire to connector b with the rap module unplugged so I can have a reference? TIA.
OutlawPerforman
Oct 30, 2017 05:40 PM
Jeff1904
Jun 5, 2016 05:00 PM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
