Raise The Rear
Old Feb 11, 2005 | 12:27 PM
86F-body's Avatar
Raise The Rear
What's a cheap way to raise the rear to give my 86 trans am that old school look. I've heard about shocks that can raise and lower with a simple bike valve type thing and all you have to do is hook up a compresser to it and "blow it up" to the hieght you want. I anyone can help it would be much appreciated.
Old Feb 11, 2005 | 01:55 PM
Re: Raise The Rear
The "old school" way to raise the back of a coil spring car (at least the way I did it on my 1966 GTO ) was "air shocks".... a shock with an internal bladder you could add air to. They also used "spreaders" on the spring coils, a couple brackets with bolts that could jack the coils apart - not a very good way to do it. Currently you could get a pair of the Air Lift 1000 bags that fit into the coil springs, and blow up with compressed air. Here's a picture of an Air Lift in a 4th Gen rear spring, which is the same as your 3rd Gen:
http://cjcfo.fbody.com/members/injun.../DCP03556a.jpg
I've also found that the Eibach Drag Launch springs will raise the back end about 1/2" - makes plenty of room for 28" slicks:
http://cjcfo.fbody.com/members/injun.../DCP03466a.jpg
Old Feb 11, 2005 | 03:40 PM
86F-body's Avatar
Re: Raise The Rear
what sort of price range are we talking for those set ups
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
RickRay
Events and Cruise Spots
Apr 23, 2015 02:50 PM
siguy
Nov 27, 2014 10:07 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
