question on 30 amp fuse to fix rear defroster
well its that time of year again and I would like to finaly fix that rear defroster that likes to kick off after a minute. I did a search on it and found most guys replace the circuit breaker with a 30 amp fuse. Is it in the fuse panel under the steering wheel in the dashboard? what exactly do I do to replace this, Do i just buy one of those double sided wires with the fuse in the middle and then soldier it to the old connections? Also how exactly does this work, since I'm replacing one 30 amp circuitbreaker for a 30 amp fuse, isn't it going to take he same amount of heat and current? Anybody have any pictures? thanks
Well I just went out there and looked over the fusebox and it looks like a regular fuse will fit in the place of the big black silver 30 amp one which I assume is the circuit breaker. Looks like it will be easier than I thought
That's why the advice is to "replace circuit breaker with a fuse".
thanks, it just seemed to easy to be true. By the way it works like a charm, it goes for the normal ten minutes or so. I'm still confussed why the fuse works better? does the circuitbreaker get hotter then switch, whereas the fuse will take more heat?
The fuse is apparently a little more robust. Keeping the same amperage still keeps the circuit protected. Just keep an eye on the fuse. It may tend to look like it gets a bit overheated. You might keep an extra in the glove box.
Thanks!
For instance you could design a fuse or breaker to pop if it "see's" 1amp for .5ms over the 30 amp normal, or it could be designed not to pop until it "see's" 2amp for .5 sec.
10-31-2016 11:09 AM
squarehead
11-21-2014 08:02 PM
