push button start
Old Jan 14, 2007 | 04:14 PM
1slow89firebird's Avatar
Smile push button start
I read through some search results but didn't find the answer I needed. both of the plastic pieces on my ignition where I put the key broke off leaving sharp points and I can't really turn the key without pain to my finger and thumb. I was thinking about push button start after seeing my friend use one in his ford truck. I want to turn the key to on and go from there. would I still have to run wires to the solenoid on the starter or whatever? my friend just turned the key to on, pushed the button once and his started. so basically can anybody help me figure out how to wire this? thanks in advance
Old Jan 14, 2007 | 04:20 PM
reamo04's Avatar
im also curious, my friend has this on his LS1, and I'm thinking about doing it to my LT1
Old Jan 14, 2007 | 06:41 PM
razor02097's Avatar
I think all you need to do is splice into the red wire to a switch then the starter wire should be yellow both can be found connected to the ignition lock. You shouldn't have to run much wire at all.
Old Jan 14, 2007 | 06:58 PM
PentaVolvo's Avatar
basically get to the ignition harness and run one wire from the fat red wire to your switch and run another wire from the fat yellow wire to your switch and you are golden
Old Jan 14, 2007 | 07:21 PM
I found this guide
http://ourworld.compuserve.com/homep...on_starter.htm
whether it works or not I will have to wait and see.
Old Jan 14, 2007 | 08:34 PM
OUTCAST's Avatar
Afriend did it to his and loves it use the button from the Honda S2000!
Old Jan 14, 2007 | 09:26 PM
unreconstructed1's Avatar
Thumbs up i did it
my 89 camaro was pushbutton. All I did was to splice into the hot wire on the outfeed end of the ignition turn the switch on and theres power to the button then the outfeed side of the pushbutton goes to the solenoid it's really quite simple.. and kind of funny when your friend cant start the car cause he didnt know it had a pushbutton. I dont know if its any different on the newer engines though. my camaro was de-brained and rean a 70's model engine
Old Jan 14, 2007 | 09:49 PM
94/96ZsM6s's Avatar
i want to see some pics of the where you guys have installed the start button...
Old Jan 14, 2007 | 11:59 PM
blackrat's Avatar
I added a pushbutton start when my ignition switch failed in my old 73. I just ran some wires from the starter and the solenoid though, routed them through the firewall, and mounted the pushbutton on a blank spot where there was supposed to be a rear defroster button. Might be easier if you don't feel like getting into your steering column. Be sure to wrap everything up though.
Old Jan 15, 2007 | 01:09 AM
seawolf06's Avatar
The smaller wire to the solenoid is the one that activates it correct? Does that just need to be connected to a 12V source and how much amperage do you think it would need? (i.e. what fuse to use?)
Old Jan 15, 2007 | 01:50 AM
Jared 3870's Avatar
I think it'd be kind of neat to do the air craft switch / push button setup. Just for ****s and giggles.
Old Jan 15, 2007 | 07:04 AM
JakeRobb's Avatar
Super Moderator
The usual approach is to replace the cigarette lighter with the button.
Old Jan 15, 2007 | 07:59 AM
mthegodfather's Avatar
Pics................
Old Jan 15, 2007 | 10:27 AM
some good approaches to installing mentioned, but I also think pics would help us all.
Old Jan 15, 2007 | 12:55 PM
sandman63's Avatar
How about under the stearing colum? Thats where one of my buddy's had his.
DirtyDaveW
Dec 1, 2016 05:37 PM
Amshnock
14
Jan 18, 2015 11:47 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
tds1213
Nov 27, 2014 12:55 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
