Push Button Start
Old Feb 1, 2004 | 04:56 PM
neonblack's Avatar
Question Push Button Start
I was curious to know where I could purchase a push button starter switch kit. Does anyone here have one installed? If so, where could I find one?
Thanks.
Old Feb 1, 2004 | 09:04 PM
Capn Pete's Avatar
Very cool idea! I'm curious to hear some ideas as well!
Old Feb 1, 2004 | 09:57 PM
anasazi's Avatar
the punks down the street just approved as well
Old Feb 2, 2004 | 10:56 AM
bombd84's Avatar
Yeah I have always wanted to also. I think that autozone/pepboys has some of them, they are kind of general application though. My friend has one on their SCCA vette and it gives it much more of a race car feeling.
Old Feb 2, 2004 | 11:24 AM
ibanez6rg's Avatar
Haven't guys been using the ones off the S2000s?
Old Feb 2, 2004 | 01:45 PM
BumpaD_Z28's Avatar
YOUR WELCOME!
http://members.***.net/pitre/s2000sw.htm
Old Feb 2, 2004 | 04:51 PM
lifbcracker's Avatar
do you still need to use a key after that? or is all you do is push the button? - also does this work on lt1 f-bodys, im pretty sure the ignition is the same right?
Old Feb 2, 2004 | 06:25 PM
unvc92camarors's Avatar
i wouldnt feel safe if you still didnt need a key after that
just seems like all the work is done for the guy who wants your car
but, i am interested as well, seems like a pretty cool idea
Old Feb 2, 2004 | 06:28 PM
I read up on it, you still must use your key for it to work. But im still unsure if the lt1 guys can use it
Old Feb 2, 2004 | 06:32 PM
how do you still use the key? do you place it in the ignition still or what?
i wouldnt see why lt1 guys couldnt use it, i'm pretty sure the ignition stayed the same all 4th gen because i havent read otherwise but...i'm just speculating
Old Feb 2, 2004 | 06:56 PM
defined
here it works like this. You tap into the 12v+ batt cord, then into the ingition wire. You put a relay on both and then attach the wires from that to the switch, so basically nothing really changes except the fact you dont have to turn the key, which wouldnt start the car anyway cause you cut the wire to the ignition lock. So instead of turning the key all the way down like you would to start, you just push the button and bamm, revvvv revvvvvv
Old Feb 2, 2004 | 07:05 PM
Capn Pete's Avatar
Re: defined
Somehow you made that sound like you don't have to use the key AT ALL.............but I (hope) think you were trying to say that instead of turning the key all the way to "start", you just turn the key to "on", then press the start button? That would make sense, and also still make use of the key.
Old Feb 2, 2004 | 07:08 PM
yup
sorry, thats exactly what I ment, you still use the key but turn it just to "on" instead of "start"
Old Feb 2, 2004 | 07:25 PM
GoFast908Z's Avatar
Member
how much does the start button cost?
Old Feb 2, 2004 | 07:34 PM
alright, yea that's what i figured
turn it to 'on' position then hit it, makes sense
i'm sure you can get the button pretty cheap off a honda parts website
