problem
Old Jan 23, 2006 | 07:59 AM
00cls1camaross's Avatar
problem
i just installed a flowtech cutout on my car and now when i go to cap it and uncap it, it has some muky oily stuff near it? any idea what this could be?
Old Jan 23, 2006 | 08:08 AM
Kraest's Avatar
Retired
Re: problem
Humidity + carbon buildup?
Old Jan 23, 2006 | 08:09 AM
teke184's Avatar
Re: problem
residue carbon mixed with water. the water comes from condesation of water vapor from the exhaust.
fairly typical
maybe drill a small hole like 1/16", in the lowest part of the cutout...to allow drainage
Old Jan 23, 2006 | 08:24 AM
Re: problem
thanks... well it is good to know that it isnt bad...
do you all that have cutouts have what i call "drone zones" which are like certain rpms where the exhaust just like resonates and vibrates so loud? mine is between 2k-2.5k.... is this normal?
well if i were to drill a hole i would have an exhaust leak and i like to cap it when i am trying to be classy
thanks for the quick replies
Old Jan 23, 2006 | 08:30 AM
teke184's Avatar
Re: problem
the drone you are hearing is just the resonance frequency...and yes it will be different from setup to setup.
a LM setup will be different from a cutout, which will be differnt from true duals...etc.
kindda like watching the antenna when you are driving...at 50mph it will be as straight as it should be. at 60mph it may be whipping around like a mistress was playing with hit.
and the hole i mentioned....if you drill a small enough one, you'll never know it was there. do you really think a 1/16" hole will make an audible increase?
but it WILL allow some water to drain out so that it isn't sitting there corroding inside the exhaust. water combined with the natural chemicals found in exhaust can create a very caustic liquid...rusting out the metal of the cutout over time. that's why most aftermarket exhausts are aluminized or stainless...to prevent corrosion from outside AND inside.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
