power window wont go up
Old Feb 19, 2005 | 05:35 PM
Big_Z's Avatar
I've got an interesting problem in my daily driver (94 park avenue ultra). When I bought it, the rear right window was taped up because the power window wouldnt work. i bought a new motor for it and took the door apart, and it turns out the problem was someone had removed the nuts that hold the window to the scissor arms off, so i put some on and it moves ok now. the original and the new motor both work, but they only go one way. if i press either the driver's door switch or the one on the door up, itll go down, but nothing will make it go back up. What would cause it to do that? Could hte switch be bad, or is it mis-wired or something? Thanks for the help
Old Feb 19, 2005 | 05:52 PM
Re: power window wont go up
The up/down on the window motors is just a change of polarity. You might find wiring help in a Buick forum.
Keenan
Jan 19, 2023 12:24 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
