power window all goofy!!
Old Nov 8, 2004 | 02:22 PM
wblocker's Avatar
the window will roll half way up then stop, if i wait a minute, it will roll up another 2 inches or so, it acts like it is tripping a breaker, then resetting automatically, do these motors have some sort of safety switch that resets if the motor gets too hot?
Old Nov 8, 2004 | 02:46 PM
Joe Bellman's Avatar
Re: power window all goofy!!
Most likely, your motor is crapping out on you. get the window up and leave it there until you get a new one. Pretty soon it will just stop all together. I put a new one in from Autozone 2 years ago and it is still working fine.
Do a search, there is a step by step on how to replace it some where on this site. Some one else help here and point him the right direction.
But yes, the motor does stop working when it gets too hot. Once it cools down a little, it will work again for little bit.
Old Nov 8, 2004 | 03:37 PM
americanmusscle's Avatar
Yup Joe pretty much sumed it all up. You might want to get a new one from jason cromer.
Old Nov 8, 2004 | 05:47 PM
Z95m6's Avatar
I would second getting one from Autozone. I've replaced both of mine years ago and they are still working fine. Also autozone gives you the lifetime warranty which you will probably need as even GM Fbody motors don't last.
Old Nov 8, 2004 | 06:45 PM
xfreshjiv12x's Avatar
Yea you need a new motor. the reason it will go up after a second or two is that it recharges some power, but it is definitely going bad.
Old Nov 8, 2004 | 08:28 PM
wblocker's Avatar
just looked at the power window motor, really looks like the same one that was in my 84z, wonder if gm ever heard of technology advancement.
Old Nov 9, 2004 | 05:03 AM
technology advancement = more more money
we all know how GM likes to save money every chance they get even if it means getting lower quality products.
Old Nov 9, 2004 | 08:36 AM
ChrisS95TA's Avatar
If you notice the motor has like 20 holes on it, I bet this motor is used on almost every GM car from 1980 on . Thats why it is 40 bucks at autozone.
Old Nov 9, 2004 | 10:18 AM
Blue89Bird's Avatar
check out the install guide at shoebox's website. Took me 45 min start to end. Hardest part is installing the new bolts in place of the rivets, but even that was like 5-8 mins for the hardest bolt. It's a piece of cake with his directions!
Old Nov 9, 2004 | 11:12 AM
SantaCruz163's Avatar
I don't want to rob this thread but I had a problem when I tried installing my passenger side motor. I follow Shoebox's guide and it was real easy to do. I drilled the old rivets, removed the old motor and installed the new motor with the new hardware. Now, I'm positive the gear on the motor was lined up with that gear looking piece, can't remember the name. No the problem is that when I try to raise the window it a sound like the gear isn't catching and the motor just sops working an i have to remove the motor for it to start moving again. I put the old motor back in and that doesn't give all slipping noise. What could be causing this?
Old Nov 9, 2004 | 04:05 PM
Blue89Bird's Avatar
could have just gotten a bad motor, wouldn't be the first time. Could also be the track binding up, did you lube/grease it at all when you replaced the motor? If not, I would get some white lithium grease and lube the track up, it will speed things up some as well.
Keenan
Jan 19, 2023 12:24 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
