power locks, interior lights, electrical problems, PLEASE HELP!
Old Jul 12, 2008 | 09:06 PM
devlbasherZ28's Avatar
Ok, so here's the deal. This stuff happened a long time ago when i had two camaros and didn't drive this one much at all, so i figured I'd get around to looking at it later, but now its been so long that I don't even remember what all I was doing. So anyway, here's the problem...
To start...its a 96 Z28. If I remember correctly, these problems started after I did a clutch replacement, so I just assumed that I didn't plug something back in right, but I wasn't about to tear it all down again to find it that day. 1) The Interior lights no longer work at all...not when I open the door, turn them on one by one, roll the dimmer switch all the way up. nothing. 2) The power locks don't work at all, whether I use the actual switch, or the keyless remote. HOWEVER, i checked it while laying under the passenger side dash, and when I hit the power lock button, the BCM clicks. Nothing happens, but it does click. The Hatch release does work, and there are no problems with the radio (but the radio is aftermarket). I mention that only because I know the BCM controls those things also. 3) the cigarette lighter doesn't work. That may be a completely different cause, but I have no idea.
So, I just tore everything down and noticed that there is a 3 "port" plug that is wired and taped very close to the cigarette lighter clip once everything is taken apart. No idea what its supposed to be plugged into if anything.
If it matters, I have an aftermarket stereo and an aftermarket alarm...not sure if that renders some plugs useless or anything.
One more thing...I think this is totally unrelated, but the speedo doesn't work after this job was done either...I wasn't very concerned about it because I have new gears and different sized wheels so it would have been pretty far off anyway....but I think I might have plugged the reverse lockout into the speedo port or something.
I'm sorry about this being so long, but I'm really trying to get this thing running well and back into good shape, so if you can offer anything at all, please do. I know there are some good electrical people on here, so I'm hoping....
Thanks in advance!
Old Jul 12, 2008 | 09:15 PM
gnomee's Avatar
Well if you plugged the wrong things in down below you may have a direct short on a circuit.
Have you checked your fuse box?
Old Jul 12, 2008 | 10:09 PM
yea...that was the one thing I did when it first happened because that didn't involve tearing it apart again. nothing wrong then, and I checked again tonight when I was working on it. anything else?
Old Jul 12, 2008 | 10:55 PM
gnomee's Avatar
Shoe box has been on here alot lately maybe he will chime in.
You may pull the fuse and check it with a meter they can be blown and not "look" bad but actually be open.
Old Jul 12, 2008 | 11:02 PM
yeah, i was certainly hoping the great shoebox would stop by. we shall see...
Old Jul 14, 2008 | 10:48 PM
well, as i thought, the speedo was totally unrelated, but the other problems still stand...shoebox, Injuneer...anyone?
Old Jul 21, 2008 | 09:50 PM
anyone?? ttt...
warmeck
Feb 5, 2015 11:04 AM
97z28k&N
Jan 9, 2015 04:58 AM
Jeff1904
Jan 3, 2015 12:00 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
