power lock actuator rod not connected
Old Feb 17, 2012 | 03:56 PM
Asylist's Avatar
Driver's side door, '96 Camaro, with keyless entry. The rod coming down off the actuator isn't connected to the latch, causing the power function on that door not to work.
Switch/wiring/all that is fine, the actuator does work as normal, it's just not connected to the latch at the bottom of the rod, and I can't see/feel where it's supposed to go. (I have a feeling that I'm making this sound more confusing than it needs to be, lol).
Is there an exploded diagram of the latch, so I can see where the end of the actuator rod is supposed to be connected?
Old Feb 17, 2012 | 06:23 PM
Asylist's Avatar
Re: power lock actuator rod not connected
Never mind..figured it out once I got the whole latch assembly out of the car. There's a rubber bushing it pops into that sits perpendicular to the two latch rods next to it, and frankly without having pulled it out of the car, I don't think I ever would have gotten it to pop back in anyways...had to twist the actuator quite a bit to get it seated.
I took a few pictures of it, and will be uploading later tonight for future reference.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jeff1904
Jan 3, 2015 12:00 AM
XtremeLt1
Sep 13, 2002 08:50 PM
