plastic bra
plastic bra
you know that stuff im talkin about on the front of vettes i see them alot...its a clear plastic bra like thing...does anyone make a cut to fit or f-body specific pretective cover for the front of our cars? and is that removable?
Re: plastic bra
What you are seeing is 3M Scotchgard™ Paint Protection Film
You can order / purchase it at auto body shop supply houses.
It is stretchable and trimable, so it can be used to cover curved surfaces.
Yes, it is removable.
Re: plastic bra
FAQ's
Can I reuse this material once opened?
No, Paint Protection film must be applied immediately upon being removed from its backing. The film can not be removed and reused once applied.
Can it be removed?
Yes. It can be removed easily and will not damage the paint. To remove the film, you must heat the surface to approximately 150°F while working a corner of the film with your fingernail. Once you have enough of the material free from the surface to hold on to, slowly pull the film from the paint.
Can it be removed?
