PCM or MAD Z?
Old Jul 29, 2006 | 10:20 AM
  #16
97TransAm's Avatar
Re: PCM or MAD Z?
Originally Posted by madwolf
Yes, just like your signature, but the other way around. First - beer, then MadZ28.com tune.
well your "method" is working for me... bahahahaha.
Just a madz28.com tune:
Dyno Run 1 (RO) Max power: 280.5 (+14.3) Max Torque: 300.4 (+3.3)
Dyno Run 2 (2nd gear pull) Max power: 277.1 (+22.3) Max Torque: 300.7 (+27.2)
GM847 cam insatll with necessary madz28.com tune:
Dyno Run 1 (RO) Max power: 305.6 (+25.1) Max Torque: 310.5 (+10.1)
Dyno Run 2 (2nd gear pull) Max power: 304.9 (+27.8) Max Torque: 312.1 (+11.4)
I recommend getting a spare PCM if you're going to be "reguliarly" getting tune updates. It will assure a timely turn around as the guys will not being waiting for someone to return a core in order to set yours up. As I stated before I am quite happy with the service. After the cam "operation", I was quite relieved to start the car up and drive it now for two weeks without any "SES".
Old Jul 29, 2006 | 10:26 AM
  #17
VK's Avatar
VK
Re: PCM or MAD Z?
Madz28, i think he's VERY helpfull. He goes way above and beyond!
Old Aug 3, 2006 | 08:50 PM
  #18
ZL1modified's Avatar
Re: PCM or MAD Z?
is Ed Wright still programming?
if not i would go with madz... i have heard nothing but good things about madz.
Old Aug 3, 2006 | 08:57 PM
  #19
anaik's Avatar
Re: PCM or MAD Z?
He's still programming, at $400 a pop. $150 for changes.
correction $350 for a tune
Old Aug 4, 2006 | 04:51 PM
  #20
TurboXL's Avatar
Re: PCM or MAD Z?
Okay I have a question for you guys then. Do you know if either sells PCMs? My stock PCM has a few areas failing and/or burnt up, so I'm thinking I need an entirely new PCM, and I might as well get it tuned while I'm at it. If either MadZ28 or PCM also sells new chips that would save me some time. I could buy one from them already programmed instead of sending one in to be programmed, since I can't cuz its jacked up.
Any recommendations on what I should do would be great guys.
Old Aug 4, 2006 | 04:54 PM
  #21
2000GTP's Avatar
Re: PCM or MAD Z?
I know madz28 does.. check out his site for pricing www.madz28.com
Old Aug 4, 2006 | 05:26 PM
  #22
97TransAm's Avatar
Re: PCM or MAD Z?
Buy another PCM from the classified section. That's what I did to make life easier.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
