Passeneger seat
Old Aug 16, 2004 | 09:09 PM
NewbieWar's Avatar
Passeneger seat
well i hardly ever sit in it but my gf always complains....
the seat wiggles like a chair does with one leg longer then another.
it goes down if u push on the portion nearest to the door and the back support... u can probably get it to wiggle 1/2 inch in either direction and its uncomfortable to sit in expecally in curves...
does anyone know whats wrong?
Old Aug 16, 2004 | 09:24 PM
Dave89IROC's Avatar
Re: Passeneger seat
make sure all 4 bolts/nuts are tight, also look at the tracks to see if they are broken/rusted through
Old Aug 16, 2004 | 09:41 PM
red96taA4's Avatar
Re: Passeneger seat
my driver seat will tilt backwards or forwards a lil bit depending on how i move in it...but i never really cared too much to fix it. maybe ill have a look at it now. all i should have to do is tighten the four screws and what not?
Old Aug 16, 2004 | 10:04 PM
TraceZ's Avatar
Re: Passeneger seat
There are two tracks on the bottom of the seat. Each track has 4 bolts in it.... 2 going into the seat, and 2 going into the floor.
Make sure they are all tight.
The 4 bolts going into the floor are easy to get to. If the oned going into the seat loose you will likely need to remove the seat to get to them. It is pretty simple eather way.
Old Aug 17, 2004 | 12:58 AM
1 Nasty Bird's Avatar
Re: Passeneger seat
yaa my passenger seat bolts are loose form the track to the seta. Gotta pull the seta to get at them bastards. Just another lil weekend project.
Old Aug 17, 2004 | 07:16 AM
Re: Passeneger seat
Might want to check the studs that hold the seat/track to the floor. They are welded to the thin sheet metal floor.
On my drivers seat, one of them broke completely out of the sheetmetal floor, and another was 1/2 torn loose. I had to put long bolts through from the bottom, with large fender washers to tighten up the seat.
Old Aug 20, 2004 | 01:20 AM
NewbieWar's Avatar
Re: Passeneger seat
thanks it was the front right bolt to the chair... got it all tightened up
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
