P0405 EGR Flow Sensor A Low Input???
Old Nov 27, 2006 | 03:52 PM
stone4779's Avatar
I have this code even though I had my PCM custom programmed & they deleted the EGR completely. The EGR has been off the car for 2 years and I want the darn light to go away!
Anyone have any ideas? I dont understand it...the code is there, but I dont even have EGR, and is was supposed to have been deleted from the PCM???
Thanks guys!
Old Nov 27, 2006 | 04:16 PM
Maybe they missed it when they reprogrammed for the delete. Its the circuit continuity check on the EGR pintle position feedback circuit.
Old Nov 28, 2006 | 10:05 AM
stone4779's Avatar
I know, but the check engine light wasnt on for like a year and then it just popped up???? Weird...
Old Nov 28, 2006 | 01:54 PM
The GM online diagnostic guide indicates that code "detects if the pintle position feedback circuit is open or shorted to ground". Code sets when the EGR feedback signal is less than 0.14 Volts. Only condition required to enable the diagnostic is system voltage is greater than 11.7 Volts.
Maybe a wire has been pinched or shorted out. Check the harness wires for the EGR system, or whatever is left (cut off wires?? taped??) since you removed the valve.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
edman
Mar 13, 2015 09:39 PM
Fatdog2
Feb 13, 2015 08:19 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
