overheating. im stumped.
Old 06-28-2015, 01:43 PM
thenewkid's Avatar
So last Monday my car overheated after stopping to get fuel. I had driven the car for about 45 mins prior to stopping. Originally I thought my csr pump went because I couldn't hear it run anymore. after installing a new meziere pump she still runs hot. also I cant hear the new pump running either... which makes me think its shorting out somewhere. its got a new relay. Thermostat still opens. anything im missing here?
thenewkid is offline
Old 06-28-2015, 02:13 PM
Re: overheating. im stumped.
Have you looked for actual flow in the radiator?
shoebox is offline
Old 06-28-2015, 02:33 PM
Did you check for 12 volts and a ground at the electric pump?
Injuneer is offline
Old 07-02-2015, 02:42 AM
thenewkid's Avatar
Ended up getting lucky. apparently the wiring for my old csr pump also had its own build in fuse, and of course it was hidden behind the radiator so I never noticed it was just a bad fuse haha... but I guess I have a spare pump now if it ever really does go bad. so to anyone still reading. always start with the small things. my 2 cents.
Old 07-02-2015, 07:16 AM
If you had checked for 12V at the pump, you would have found the problem without "getting lucky".
Injuneer is offline
ryanhilsgen
9
09-21-2015 07:34 PM
AlaskaZ28
12-10-2014 02:39 PM
AlaskaZ28
12-10-2014 02:37 PM
Blacker2000SS
3rd Gen / L98 Engine Tech
05-07-2003 06:57 PM
Quick Reply: overheating. im stumped.
