Outer window rubber
Old Sep 12, 2006 | 02:12 PM
CamaroFan71's Avatar
Outer window rubber
Apparantly mine had decided to come lose. I noticed inside the door it appears to clip inside the door somehow. I tried pushing mine back down but it keeps popping lose. How do I fix this? Thanks.
Old Sep 12, 2006 | 02:55 PM
2001NBMZ28's Avatar
Re: Outer window rubber
Is it torn or something? Can't remember how mine clips on, might have to pull the inside door panel. If you need a new one they're pretty expensive, from the dealership at least - ($52). Different PN depending on which side it is.
Old Sep 12, 2006 | 03:36 PM
yeah I pulled the inner panel off and saw its clipped onto the door with clips. But when I pushed mine back down it popped right back up. guess I'll get a new one and see if that helps. Its not torn so its alot of money if it doesnt work. Thanks man.
Old Sep 12, 2006 | 04:04 PM
2001NBMZ28's Avatar
Maybe you can "rework" the clips or something? Here's the PN's if you need them:
RH - 10284222
LH - 10284223
Old Sep 12, 2006 | 04:08 PM
RH - 10284222
LH - 10284223
Thanks man. I'll check prices today. May be a good weekend job.
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
