Optima Yellow Top
Old Nov 2, 2005 | 12:57 AM
eagleknight97's Avatar
Question Optima Yellow Top
Planning on replacing my battery around thanksgiving and im sold on an Optima, but im not sure which one I want to get. Currently I dont have anything audio wise more than a aftermarket head unit, however, this coming summer, i plan on adding two fairly low powered amps to my car. I know I would probably be just fine for many years with a Red Top, but I kinda like knowing that I can drain the yellowtop a number of times and it will be real close to the original charge. Im not real concerned with the added cost of a yellowtop, but just wondering if it will actually benefit me in any way. And any additional info on the yellowtops would be great, cuz im still pretty hazy on what exactly a deepcycle battery is. Thanks!!!
Old Nov 2, 2005 | 01:25 AM
masiroc566's Avatar
Re: Optima Yellow Top
You can check out this guys website....I find him to be the cheapest as far as the Optima's go...but see if there is a better deal where you live first....If you go to the Optimabatteries.com.....it will show the info..u need....http://mrksales.com/ click on the auto section...
Old Nov 2, 2005 | 01:40 AM
Thanks...also anyone know what the biggest battery I could fit in the stock location? I think the model number that they give for the car is 75/35, but im not sure. Thanks
Old Nov 2, 2005 | 02:25 AM
masiroc566's Avatar
Take your measurements...thats all u need...
Old Nov 2, 2005 | 02:32 AM
masiroc566's Avatar
I personally like the yellow top 34T.....lots of cranking amps!!
Old Nov 2, 2005 | 03:17 PM
Anybody got anything else as far as whether or not a yellow top is worth it?
Old Nov 2, 2005 | 04:27 PM
Bert02SS
Guest
Posts: n/a
I may have missed it, but did you say how much it was going to cost you?
Old Nov 2, 2005 | 05:20 PM
RicocheT's Avatar
Whats the difference between the yellow and red? or blue, whatever. I've looked.. the red has higher cranking amps than the yellow, BUT the yellow has a couple models with over 1000 cranking amps..
Can anyone shed some light on the different types? I've always used red myself
THanks
Old Nov 2, 2005 | 07:32 PM
Dave89IROC's Avatar
red is standard auto starting batt., yellow is dual purpose(starting/deep cycle) and blue is pure deep cycle
Old Nov 17, 2005 | 03:58 PM
Anybody else got any input/advice
Old Nov 17, 2005 | 04:11 PM
'99 SS's Avatar
I replaced my original battery with the OPTIMA Red Top I researched which OPTIMA battery was best for my car on OPTIMA's website, and if I recall, the Yellow Top was more expensive, not necessay, and really wouldn't be any better for my application.
I purchased mine at SEARS Automotive Center.
OPTIMA batteries are pretty good. The SS is pretty much put in storage for the winter, and I was told the OPTIMA Red Top will hold a charge longer.
Old Nov 17, 2005 | 05:41 PM
Bert02SS
Guest
Posts: n/a
Found some battery acid in my driveway, noticedthe positive post leaking this morning. Replaced original battery with Optima Red Top, $104 at Costco. OEM battery was 525 cold cranking amps, the Red Top is 720 CCA.
Old Nov 18, 2005 | 06:57 PM
izzyz28's Avatar
Two years ago I was given an Optima red top. It had been in my boss' car(Caprice with a 502), and had been sitting on the garage floor for the better part of a year. I put it in my car, never had to charge it, and it's been going strong for two years now. It cranks over great in the winter, and has never once given a hint of any problems.
Old Nov 19, 2005 | 12:16 AM
Where is the best place to get an Optima? I went to both Pep Boys and Autozone and they quoted me 110 for the battery. That about as good as it gets give or take a few bucks? Also, does Interstate rebadge Optimas when they sell them, or are they normal looking Optimas?
Old Nov 19, 2005 | 03:32 PM
'86 350's Avatar
110 is about what they'll go for. That's for the Red Top right? Not sure on your second question.....
guyomatic
Sep 11, 2002 02:11 AM
JSK333
Sep 9, 2002 10:33 PM
ur2slo50
Aug 30, 2002 10:45 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
