oil smell coming from vent
Old Aug 13, 2008 | 12:12 PM
LT1 FUN's Avatar
after the car has been warmed up 15-30min and I turn the air conditioner from max to norm or just to vent (air off) there is a slight hot oil smell coming from the vents- checked for oil leaks and the only one I found was a little seepage fron the back of the intake, not even wet. Could there be a vacum line behind the dash thats cracked a bit? car runs perfect otherwise. Thanx
Old Aug 13, 2008 | 04:26 PM
Granite00's Avatar
The cowl between the hood and the windshield is where air for the HVAC system pulls in air. When you have it set on Max, a vent door opens up under the dash that recirculates the already cool air inside the passenger compartment. That's to help the AC work better because it doesn't have to cool humid hot air that way. Anything that's burning in front of the car will get sucked in with the air comming into the car. You need to fix the oil leaks.
HectorM52
Jul 30, 2017 11:46 AM
MattFick
Feb 15, 2015 10:16 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
GigaMp3z
Feb 20, 2003 02:57 PM
