oil pressure and vent air problems in traffic jams
Old May 31, 2008 | 10:28 PM
FNDRB58's Avatar
Oil pressure goes to zero after I'm in a traffic jam for a few minutes. I have to press on the accelerator a bit to keep the psi up and keep the car from dying. Once I get going, the oil pressure is fine, even at stoplights.
Also, while in this same traffic jam the vent air is hot while the weather outside is mild or cool. Then, when I get going it is cool. I understand why it is getting cool but why does the vent air get hot?
Why, why, why?
Old May 31, 2008 | 10:49 PM
guidi's Avatar
I'm having that exact same problem right now with my 95 trans am. It's the oil pressure sending unit. part is $25 it's on the back of the intake by the steering shaft. It's a pain in the *** to get to.
Old Jun 2, 2008 | 11:11 PM
FNDRB58's Avatar
I hope that's it. Thanks for the help.
Old Jun 4, 2008 | 03:07 PM
FNDRB58's Avatar
Is the sender the same as a sensor?
Old Jun 5, 2008 | 08:27 PM
Oxygen454's Avatar
yep, exactally the same thing just different way of explaining the part. This is located on the top rear of your engine if it is the same as my 96. shbox.com had more info and pictures on this as well.
I had the same problem, read my thread if you are interested... Oil Problems
Oxy
Old Jun 6, 2008 | 12:31 AM
FNDRB58's Avatar
Oxy
Thanks. And I read your thread. I didn't see any results....was the sending unit your problem? I thought I read that you had already replaced the sending unit to no avail.
Old Jun 6, 2008 | 07:52 PM
Oxygen454's Avatar
Yeah I changed my sending unit and that didn't help. I just waiting for a A-pillar attachment to hold my mechanical gauge for my car. The feed back I got from many people and other forums is that the wiring is either messed or the gauge. Some say bearings in engine but when I put a gauge on the car, the psi read normal. This had been ongoing for a year and a half now.
My advice, gauge the engine, check the wiring and if the pressure is okay get a new oil sending unit/sensor or an mechanical gauge in your car.
Old Jun 6, 2008 | 11:05 PM
FNDRB58's Avatar
Old Jun 7, 2008 | 02:25 AM
Oxygen454's Avatar
No problem let me know how it goes and in turn if I have any updates, I will get back to you too.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
