Oil pressure gauge ?'s
Old May 10, 2009 | 07:04 PM
nitrofinch's Avatar
I am trying to put in a auto meter oil pressure gauge but im not sure to tap into. any help would be great
Old May 10, 2009 | 07:27 PM
NJ-LE's Avatar
nitrofinch:
95s have a port in the side of the block just above the oil filer pad. 1/8" npt works. (I think the 93's (?) had the oil pressure gauge sensor there but ours use the port on the top near the fuel pressure regulator)
Old May 10, 2009 | 09:50 PM
SSCAMARO1659's Avatar
trying to do the same for my 99ss, they put the oil gauge in the pod but I found the tubing tucked under the dash. It was never installed. Is that in the same location for my 99. Also where is that port exactly
Old May 10, 2009 | 10:56 PM
LS1 (your 99) and LT1 (his 95) blocks are a bit different. Not likely they would have the spare pressure tap in the same location.
On the LT1, Shoebox has a photo:
http://shbox.com/1/aux_oil_port.jpg
....but "just above the oil fil(t)er pad" is a pretty accurate description, even without the photo.
Old May 11, 2009 | 08:57 AM
thanks, I will look to do the install on the next oil change. Probably easier to do it then or can I do it before.
Old May 11, 2009 | 11:47 AM
NJ-LE's Avatar
nitrofinch:
I used that port for an "idiot light" oil pressure switch to ground a light and warning buzzer but I remember the port is recessed a little and with the lip of the filter pad interferring I needed to use a short male-female 1/4" x 1/4" stand-off fitting between the block and the switch.
SSCAMARO1659
This works for the LT1 blocks ... I don't know where a spare pressure side, oil system port is on LS blocks.
Old May 11, 2009 | 04:34 PM
Spartan7's Avatar
The LS1 should have a similar port right above the filter. I'm not sure what is involved with the install though. Post #3:
http://www.pirate4x4.com/forum/showthread.php?p=9535090
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
KYWes
Apr 15, 2015 05:48 AM
Z28countrymama
Jan 22, 2015 02:50 AM
