No Power When I Get on the Accelerator?!?!?!
Old Mar 28, 2006 | 02:01 PM
khojo16's Avatar
ok well i have new taylor ovc's on, with fire sleeving, and a new coil and my rpms will move down and up a lil bit when idling, but wen im cruising and in 2nd gear on up to 6th, whenever i get on it and slam the accelerator, the car doesnt move or haul a$$ like it should...also, wen i come to a stop and let it idle it drops a little lower than normal sometimes...any ideas??
Old Mar 28, 2006 | 02:23 PM
teke184's Avatar
Re: No Power When I Get on the Accelerator?!?!?!
fuel pressure?
you checked all your plug wire connections and coil?
Old Mar 28, 2006 | 02:41 PM
khojo16's Avatar
yeah plugs/wires and connections and coil are brand new and connected perfect...i had a feeling it might have sumthing to do with fuel pressure as well..now heres a pic of a line (i think a fuel line) that my ******* father snapped when messing with my car..and the two broken ends are just connected together by a soft rubber hose...
is it maybe not holdin enough pressure???
Old Mar 28, 2006 | 03:12 PM
OBE1 95Z28's Avatar
That's the line that goes back to charcoal canister. Only fuel vapor is in that line so I don't think that's your issue. Double check that all the spark plugs boots are snapped properly over the plugs. What shape are your spark plugs in and what brand?
Old Mar 28, 2006 | 03:16 PM
khojo16's Avatar
brand new spark plugs gapped at .050 and they are NGK TR-55's...everything is connected correctly...to me it seems like a vaccuum issue...but i duno where to start..
Old Mar 28, 2006 | 06:33 PM
khojo16's Avatar
ok i took the car out and after about a mile of driving the SES light came on so i took it back home and the code read "cylinder 6 misfire"...so theres my problem...not vaccuum or fuel...
Z28Freak86
Apr 30, 2024 05:37 PM
Keenan
Jan 19, 2023 12:24 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
armedtrigger
Feb 24, 2015 08:30 PM
XtremeLt1
Sep 13, 2002 08:50 PM
