no power from cruise control switch
Old Jul 5, 2012 | 09:54 PM
Gtpguy's Avatar
Mech says power is going to it, but no power is coming from the cruise control switch. So I bought a new one, but cruise still isnt working.
What ive verified:
3rd brake bulbs are good
Brake switch is snug and in good condition
Cruise control module is brand new
Cruise control / turn switch is brand new
Any ideas?
Old Jul 5, 2012 | 11:41 PM
Re: no power from cruise control switch
The cruise portion of the multi-function lever gets power from fuse #12 in the underhood box. Do you have 12V at the pink wire to the multi-function lever (pin M in connector C215)?
The mutli-function lever has three output wires in connector C215:
Pin L - Gray wire, turns system on/off, to pin A on cruise module
Pin K - Dark Blue Wire, set/coast, to pin B on cruise module
Pin J - Gray/Black Wire, resume/accel, to pin C on cruise module
When you move the slide switch from off to on, you should see 12V on the gray wire. You will only see 12V on the other 2 wires when using the momentary contact feature for set/coast or resume/accel.
Old Aug 11, 2012 | 10:07 AM
zmike's Avatar
Just a thought. But in front of the computer is a vacuum connection or tee and my cruise control did not work because I had a vacuum leak there. A couple hard lines connect to this.
Old Aug 11, 2012 | 03:56 PM
Is this what you are talking about?
http://shbox.com/1/vac_check_valve.jpg
Old Aug 11, 2012 | 06:54 PM
kartracer13's Avatar
Did you change the tail lights to LED's?
The cruise won't work with LED's. I know there's a fix for that,but I'm not really sure how to do it.
Old Aug 12, 2012 | 02:33 PM
zmike's Avatar
Yes. That is it.
Old Aug 12, 2012 | 10:52 PM
ACE1252's Avatar
These may help....
Index of /1996_Z28_Factory_Manual_Snapshots/Cruise_Control_Electrical_Diagnosis
Old Aug 13, 2012 | 05:03 PM
Yes. That is it.
Seems odd that the HVAC vacuum check valve would have anything to do with the cruise control.
meissen
Jun 1, 2015 07:59 AM
Jan 23, 2015 01:13 PM
XtremeLt1
Sep 13, 2002 08:50 PM
slothgrant
Aug 22, 2002 03:01 PM
