No clutch pressure on 94z.
Old Nov 25, 2010 | 11:35 AM
Kurt Crosbie's Avatar
I noticed the past couple of weeks it was getting harder to shift, then all of a sudden I noticed the pedal got real soft and I can't shift at all. The last time I had a problem like this it turned out to be the slave cylinder. Just wondering if I should go ahead and replace that or if there is some other troubleshooting I should do first. Thanks.
Sent from my ADR6300 using Tapatalk
Old Nov 25, 2010 | 02:04 PM
Re: No clutch pressure on 94z.
Did you check the fluid level?
Old Nov 25, 2010 | 02:07 PM
Wow. I'm not even going to erase this. I want to allow everyone to just laugh it up because that was just pure stupidity. There's no fluid, hence no pressure....
Old Nov 25, 2010 | 04:02 PM
Which probably means the slave is leaking. You should see some fluid in the bellhousing.
Old Nov 27, 2010 | 01:23 PM
Add that to my oil leak. I went to raise the car up on stands, but it looks like I need a bigger jack to get it high enough to get under. However, I was able to see that there was no oil in front of the oil filter, which I assume is very close to the oil pressure sending unit, so I assume that is where the leak is coming from. I did notice some fluid at the front of the bellhousing. At this point, that could be a combination of both leaks. I guess the bottom line is... I need to get to work!!!
Matt W
Apr 24, 2015 12:54 AM
BigWil
Mar 29, 2015 12:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
HectorM52
Jan 30, 2015 11:08 PM
