No airflow on heater
Old Oct 29, 2010 | 12:34 AM
JsnTnn's Avatar
My heater has left me in the cold the past few weeks and I'm tired of it. On A/C the airflow is fine (not great) but I can feel it, now that I need it to blow heat, it has failed me. I can put my hand on the vents and it feels somewhat warm but there is no airflow at all.
I'm don't really know how the HVAC system works, I took a glance a Shoebox's site but I'm still lost. I don't see how a clogged heater core could reduce the airflow so I'm thinking it is another problem. The check valve by the firewall appears (visually) fine.
Basically I go from plenty of airflow on A/C to no airflow on heater. Any ideas?
Edit: This is on a 1995 Z28 by the way.
Old Oct 29, 2010 | 05:12 AM
Shoebox has a diagram of the system. You will see that the temperature **** turns a cable, that moves the flapper door from AC to heat. Could be the cable is loose or broken. Additionally, where the air blows from is controlled by flapper doors that are vacuum powered. Often, the check valve breaks, or a vacuum line cracks.
http://shbox.com/1/hvac_vacuum.jpg
http://shbox.com/1/vac_check_valve.jpg
Use the "Signature" feature to provide basic info about your car - year, model, engine, trans and any major mods. That eliminates the need for a "by the way" edit
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
karpetcm
Aug 14, 2015 03:02 PM
Jan 23, 2015 01:13 PM
