Newb with Gas Gauge Problem
Hey guys, I just got a 93 Firebird Formula, good condition for the most part with 80k on her. The gas gauge doesn't work. After fill up, it will go to F, then keep track till you hit about 3/4th's tank. Is this a problem I need a new sending unit for? Are they hard to change, do I need to drop the tank? Thanks in advance guys!
Re: Newb with Gas Gauge Problem
the tank is shaped like an upside down cam lobe...the top is wider and takes longer to deplete. once you get below about 1/3 it really starts eating away at the guage. if you're really concerned about it, check the mileage it takes to get from completely full to about 1/2 then check how many miles it takes to get from 1.2 to 1/4. fill it back up to 1/2 (paying attention to how many gallons you put in) then fill the rest of the way. the mileage should be the same...around 23 for a stock motor. i was getting about 25 when i was stock and now i'm getting about 23 with my 383
Don't drop the tank, it's not worth it. Look up the access hatch on here if you decide to do anything to the tank. I've dropped the tank and cut the hole with my buddy on his Trans Am and the hole is a whole lot easier.
Originally Posted by JakeRobb
I fill up when the light comes on...
i usually fill up at the 1/4 too...but a few times i let it get waaay down there, uncomfortably so.
Originally Posted by Severous01
woa...you have a light??? either i've never let it get that low or i dont have one.
My tank has about four gallons left in it when the light comes on, but the needle is one needle-width above the empty slash.
Actual empty must be way below the E, because I let it get down there the other day and there were still two gallons in the tank.
Originally Posted by mitchntx
Do you realize the fuel acts as coolant for the pump?
If you ever run out of gas, you will overheat the pump and it will have to be replaced. It ain't cheap, either.
As I said, there were two gallons left in the tank. I don't plan on letting it get much lower than that.
When I fill my car up it goes way past the F. One day I ran it low to right about the E. I filled my car up at a station and it held almost 15 gallons of fuel. I now know when my needle is approaching the E my car is burning vapors.
99TransAmWS6
Feb 12, 2015 07:23 PM
slothgrant
Aug 22, 2002 03:01 PM
