Newb with Gas Gauge Problem
Old Aug 2, 2006 | 08:50 PM
RyanD's Avatar
Hey guys, I just got a 93 Firebird Formula, good condition for the most part with 80k on her. The gas gauge doesn't work. After fill up, it will go to F, then keep track till you hit about 3/4th's tank. Is this a problem I need a new sending unit for? Are they hard to change, do I need to drop the tank? Thanks in advance guys!
Old Aug 3, 2006 | 08:19 AM
Severous01's Avatar
Re: Newb with Gas Gauge Problem
the tank is shaped like an upside down cam lobe...the top is wider and takes longer to deplete. once you get below about 1/3 it really starts eating away at the guage. if you're really concerned about it, check the mileage it takes to get from completely full to about 1/2 then check how many miles it takes to get from 1.2 to 1/4. fill it back up to 1/2 (paying attention to how many gallons you put in) then fill the rest of the way. the mileage should be the same...around 23 for a stock motor. i was getting about 25 when i was stock and now i'm getting about 23 with my 383
Old Aug 3, 2006 | 11:04 AM
multicar's Avatar
Before I'd drop the tank, try a can of drygas in the tank a couple of times and see if it clears up. Strange as it sounds, something in it cleans the sender unit.
Doug
Old Aug 3, 2006 | 02:10 PM
Wickman's Avatar
I don't even use the fuel gauge. I reset the trip meter every fillup. When it hits 200, I fill it up.
Old Aug 3, 2006 | 02:25 PM
JakeRobb's Avatar
Super Moderator
I fill up when the light comes on...
Old Aug 3, 2006 | 03:37 PM
Craddock's Avatar
Don't drop the tank, it's not worth it. Look up the access hatch on here if you decide to do anything to the tank. I've dropped the tank and cut the hole with my buddy on his Trans Am and the hole is a whole lot easier.
Old Aug 3, 2006 | 06:37 PM
RyanD's Avatar
Is the low fuel light seperate from the sending unit, so even with a bad sending unit it will light up when I'm actually low on gas?
Old Aug 3, 2006 | 07:31 PM
Severous01's Avatar
woa...you have a light??? either i've never let it get that low or i dont have one.
i usually fill up at the 1/4 too...but a few times i let it get waaay down there, uncomfortably so.
Old Aug 4, 2006 | 06:56 AM
JakeRobb's Avatar
Super Moderator
It's the "Check Gauges" light.
My tank has about four gallons left in it when the light comes on, but the needle is one needle-width above the empty slash.
Actual empty must be way below the E, because I let it get down there the other day and there were still two gallons in the tank.
Old Aug 4, 2006 | 07:59 AM
mitchntx's Avatar
Do you realize the fuel acts as coolant for the pump?
If you ever run out of gas, you will overheat the pump and it will have to be replaced. It ain't cheap, either.
Old Aug 4, 2006 | 08:22 AM
JakeRobb's Avatar
Super Moderator
Yes, I know how fuel pumps work.
As I said, there were two gallons left in the tank. I don't plan on letting it get much lower than that.
Old Aug 4, 2006 | 08:39 AM
01Z's Avatar
01Z
I had a pump fail on me on the road. It was towed to a garage instead of my home. I paid $550 to have it installed and ended up with a change in my gas gauge calibration. I found out the hard way that the car runs out of gas before the gauge shows 1/8 of a tank. New pump and I already stressed it. I can smell gas now when the tank is near full. I suspect the filler neck got cracked during the tank removal as the splash cup ended up getting broken. One of these days I will pull the tank down myself and see about straightening out these foobars. My life is too full of these borked garage repair stories.
Old Aug 4, 2006 | 09:36 PM
Cerwin Vega Fan's Avatar
When I fill my car up it goes way past the F. One day I ran it low to right about the E. I filled my car up at a station and it held almost 15 gallons of fuel. I now know when my needle is approaching the E my car is burning vapors.
Old Aug 5, 2006 | 01:37 AM
shock6906's Avatar
Fill your car up at the "half tank" mark and you'll never have to worry. I've only let it go below the quarter mark a handful of times in my 3+ years of ownership.
DetroitZ28
Feb 13, 2015 07:33 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
blac94Z
Nov 24, 2014 07:12 PM
slothgrant
Aug 22, 2002 03:01 PM
simple
Aug 11, 2002 11:56 AM
