New Z28 new questions
Old May 21, 2008 | 10:23 PM
Eric1987's Avatar
So I recently purchased http://www.lahabramotors.com/used_ve...7e7ca83&bhcp=1
And I have a few questions. It has the 12 disc changer. When I put a CD in the top one and close it. I go to my car and I press the AUX TAPE and it shows disc 12 and then a few seconds later it says Err. Anything I could be doing wrong? Its a legit disc.
Old May 22, 2008 | 02:46 AM
95camaroinok's Avatar
Have you tried running a cd cleaner through it? If you have or if that doesnt help, and no cd at all will play in it, then it is probably worn out. Check the for sale section here and ebay for a factory replacment.
Old May 22, 2008 | 05:09 AM
You might want to post this in the "Car Audio and Electronics" forum.
Old May 22, 2008 | 09:28 AM
Eric1987's Avatar
Sorry can someone move it? And am I doing anything wrong when I put it in? As far as am I suppose to go to the TAPE AUX button?
Old May 22, 2008 | 11:49 AM
Z28SORR's Avatar
Are you putting the CD in with the "right' side up. If I remember correctly, the gold side should be up. Also make sure the door is closed all the way, this is a known problem.
Old May 22, 2008 | 12:05 PM
ZZ's Avatar
ZZ
Mine did the same thing. I took the cover off and cleaned the lens with a swab and some alcohol. Presto, works mint now.
Old May 22, 2008 | 02:12 PM
Eric1987's Avatar
How do I open it up what do you mean?
Old May 23, 2008 | 09:17 PM
TheZ_project's Avatar
Becareful using alcohol on the lens. it makes the plastic degrade faster and will usually leave a film. Try using something like eye glass cleaning solution or contact lense cleaner. I know some of them have alcohol in them aswell but it is in such a small amount it should not cause an issue. Also there is a great cleaner specifically for plastic lenses of all sorts I believe it is called Plextor. It is in a black can with blue graphics. I used it on mu paintball mask lenses.
Old May 25, 2008 | 04:01 PM
Fuel Fire Desire's Avatar
Ive had my disc changer just up and stop working all together. Every disc would just read ERR. I ended up unplugging and reconnecting the wire harness on it. Worked fine since.
Noenav
Mar 1, 2019 07:38 AM
cmdeshon
Jan 4, 2015 11:15 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Brent94Z
Mar 21, 2002 04:44 PM
