New condenser...now AC sucks.
Old Jul 21, 2006 | 05:53 PM
tiznodd's Avatar
Angry New condenser...now AC sucks.
The original AC system worked just fine, but the car would overheat when the AC was on because the factory condenser was plugged with 100k worth of road debris. Long story short: I installed a new condenser and now the AC blows only slightly colder than ambient temp. Its not a 134a pressure problem as I have gauges and have tried it at several pressures which made no difference. Also ran cold hose water over the condenser and that made no difference, so its not an air flow problem. I'm thinking defective condenser...maybe its internally clogged??? Any ideas or comments would be greatly appreciated.
Old Jul 21, 2006 | 06:16 PM
n2ceptor's Avatar
Re: New condenser...now AC sucks.
Did you flush and vacuum the system?????? If not, this might be your problem....
Old Jul 21, 2006 | 06:20 PM
tiznodd's Avatar
I didn't, and I realize thats bad, but I have filled the system several times in the past without pulling a vacuum and it still would blow cold. I'm just looking to get by for the summer, but as it sits the thing doesn't even blow cold enough to justify turning it on.
Old Jul 21, 2006 | 06:33 PM
You're going to need at least what n2ceptor said. It's really a basic requirement when replacing parts.
Old Jul 21, 2006 | 08:13 PM
Cmr0z28's Avatar
Evacuate system,
replace expansion valve and drier, have **** flushed if you want,
vacuum for at least an hour,
recharge
Old Jul 22, 2006 | 11:53 PM
CamaroZBoy's Avatar
as all have stated here...anytime something related to the air conditiong is opened up or broken....its kind of a rule of thumb to "refresh" for lack of better terms. Make sure the vacuum sucks real good...NO CLOGS
CC
Old Jul 23, 2006 | 12:34 AM
dannyum89's Avatar
For some reason when your A/C system has a small leak and all you do is add freon there doen't seem to be a problem. When you change a part and the whole system evacuates then that becomes a problem. I don't know the answer to that. I had a leak and I kept adding freon, everything worked fine. Then I changed evap, refilled it and everything went to crap. Unexplainable.
Old Jul 23, 2006 | 12:36 PM
tiznodd's Avatar
Thanks for the advice fellas. I guess I will just spend the money and have someone vacuum it and possibly flush it.
Kawi
Sep 28, 2015 09:01 AM
darkoverlift
Dec 8, 2003 04:34 AM
oil pan 4
3rd Gen / L98 Engine Tech
Dec 4, 2002 10:58 PM
