new clutch
i put a ram power grip in i think i cant rember the exact one but i know it was a ram a little heaver then stock and loved it babyed it for like 800 miles but was not disengaging right so we pulled it Back apart. the cluch plate was jacked up the fingers were all diffrent hights so called summit the sent me a new one put it it runs great but in first grear takeing off from a compleat stop it spools more of like a grinding sound its a hard sound to explain not all the time eather so i dont know if any of you guys have heard of this befor and its just a regular take off not a lanch or any thing
hey im very sorry about that, I really dont know how i forgot that its a 97 ss 6 speed has about 49xxx on it now um i replaced all the breaings in the clutch and also i had to replace some seals and like i said its only on like a normal take off seams to do it alittle more on a hill and turning but doing all 3 at once and only if you let it all the way out makes the noise for maybe ten seconds at the very most maybe once a week. I really hope some one dont tell me its the way i let it out because its done it to more then jusy me kinda sounds like a spooling sound like a rrreeeettttt noise i really dont know
thanks guys
thanks guys
Re: new clutch
Can you post a link to the unit you bought? I assume it came with a friction disk, pressure plate, throwout bearing, and pilot bearing.
Are you sure the throwout bearing was installed correctly(with the retaining ring and such)? Who installed the unit and were all the proper torque values for all the bolts used in the install(extremely important!!!)?
Re: new clutch
ill have to look it up get u the link and im kinda sure they did it here at school and the teacher watched over it very well and if not doing most of the work
ill get back with u on the rest
