never thought of it??
Old Sep 12, 2007 | 06:01 PM
Michael943's Avatar
hey my dad owns a salvage yard n i jus thought of something. is there anything i could use and put on my car to make it fast like rear ends and transmissions from other cars we have plenty of gm and 12-bolt rear ends could i use some of them??
Old Sep 12, 2007 | 07:22 PM
Dave89IROC's Avatar
depends, what kind of car you have?
Old Sep 12, 2007 | 09:36 PM
Michael943's Avatar
98 ss
Old Sep 13, 2007 | 07:49 AM
ok.... and what transmission do you have now - M6 or A4? What rear axle ratio do you have now? Is it a 3-channel (ABS only) or 4-channel (ABS + TCS)?
It would help if you added a "signature" with info about your car, so people could answer your question without asking you a whole bunch more.
Old Sep 13, 2007 | 11:27 AM
Z28SORR's Avatar
For the 5000ths time!
Old Sep 13, 2007 | 05:23 PM
likittysplit's Avatar
You cannot make your car any faster than it already is with junkyard parts unless you gain some first hand knowledge and do some research on your own. This is not a plastic model that you just glue together!
Old Sep 17, 2007 | 10:26 PM
RE AND CHERYL's Avatar
Unless your father just bought a heads/cam LS1 car or one with headers from an insurance company, he's got almost nothing you need.
If he has a 01-02 F body, they have the better LS6 intake. That would be a good find.
Re'
Old Sep 17, 2007 | 10:33 PM
Irish350's Avatar
true, but he could also get a better rear end, better gears, better suspension etc (depending on what all this junk yards packin)
Old Sep 18, 2007 | 12:11 PM
White96Z28's Avatar
I'd say there is a pretty good chance you'll find a TH-400 and a 12-bolt or 9" around there that you could make work, but you're not going to find anything that you could just swap out without doing some pretty major modification or rebuilding... And we're not even sure what your goals are for this car, so it's really hard to make suggestions on what will work and what will not.
Old Sep 19, 2007 | 11:55 AM
teke184's Avatar
since you have the 98....any 01-02 ls1 fbody would have the ls6 intake manifold
if you have an auto transmission, it would be possible to upgrade the rear gears.
some autos came with 2.73 gears, others with 3.23...which would be an upgrade
the manuals came with 3.42 gears wich would also be an upgrade. but as stated you need to confirm which style (3 or 4 channel) you have.
an 01-03 corvette ZO6 would be a GREAT upgrade as far as engine parts: heads, cam, intake
the 5.3L chevy trucks have heads that would swap, you'd increase your compression. but your best bet is to use them as cores for porting. same goes for the 6L versions.
if you're an auto with 2.73 gears you have the steel driveshaft. you could pick up a few hp at the wheels by swapping to an aluminum one off of a auto-3.23 equipped or manual equipped car.
cmsmith
Sep 14, 2015 09:25 PM
MDZ28
Sep 7, 2015 09:16 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
4586
Aug 24, 2015 11:04 PM
dkred94z
Aug 20, 2015 03:09 PM
