Needs wiring help
Old Dec 13, 2007 | 04:06 PM
mdacton's Avatar
Needs wiring help
Need help wiring fans. Do not have PCM or wiring but have the 2 plugs on pass side strut tower.
How do I trigger the 2 wires to cut the fans on? If I can just cut them both on hi speed with a switch it will be all I need.
Hooking 6 speed safety switch to a shifter for an auto, do you just need to hook the to wires to the switch and thats it? I did that and not getting anything out of the ignition to the purple wire. I do have an external solenoid I am using. And the starter is just looped.
What wire does the volt gauge hook to? does it need to plug into the alt?
Old Dec 13, 2007 | 10:19 PM
If all the wiring forward from the shock tower connectors is in place, all you need to do is hook the blue and green wires together to a switch that will provide a ground when operated. Both wires must be grounded for high speed operation using the stock relay system.
Old Dec 14, 2007 | 06:41 PM
mdacton's Avatar
I got everything working but the volt gauge.
What do I need to do to make that work?
Thanks for the help so far shoebox, Wiring is one of my least favorite things to do. I'm also soldering/heat shrinking everything so this is taking me a long time
Old Dec 15, 2007 | 08:40 AM
Any 12v source should operate a volt gauge.
Old Dec 23, 2007 | 02:12 PM
mdacton's Avatar
I have them all hooked up, still nothing is working.
I'm not getting 12v to the cluster....fuses are good, everything is hooked up like it should be( I have ohm each wire back to 220 and 230) I can't figure this out
must be over looking something...possibly a ground for the gauges? I have not found one in the wiring diagrams
Old Dec 24, 2007 | 09:55 PM
mdacton's Avatar
Figured it out...mostly
Blk with wht stripe....needs to go to ground, Tach still isn't working
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
