Need help with transferring weight
Old Jul 19, 2008 | 12:37 AM
reamo04's Avatar
So, im trying to figure out the best ways possible to help my car transfer weight.
Right now I
deleted front sway bar
moved battery to trunk
LCA relocation brackets
alternator only setup
I know the main things that will help are removing weight from the front, and a torque arm. Anything else I cant think of (givin it is almost 1 am).
Old Jul 19, 2008 | 02:40 PM
Wicked1's Avatar
gut the interior and hvac
Old Jul 19, 2008 | 08:07 PM
H2O's Avatar
H2O
Only other thing I can think of is removing AIR pump. I thought it was about 10-15lbs or so.
Old Jul 20, 2008 | 10:21 AM
You're addressing two different issues.... 1) weight removal/relocation, 2) and "transfer" - the dynamic weight shifts that occurs on launch. If your primary concern is reduction, go through this list and see what you can run without:
http://ls1tech.com/forums/showthread.php?t=846228
If its weight "transfer" during launch, tell us what you've done to the suspension so far. Things to look at:
-Adjustable front shocks that can be set "looser" to let the front end come up easier, and hold it there.
-poly torque arm bushing and tranny mount, or a TA that mounts to the chassis rather than the tranny tailshaft
-LCA's with rod ends
Moving the battery to the trunk usually adds weight to the car because of the heavy wire and vented box/hold-down, plus the kill switch. I opted for a light weight battery in the stock location, and save 11# off the front, without adding weight anywhere else.
Old Jul 20, 2008 | 10:35 AM
reamo04's Avatar
yeah, i had to do the battery in the back due to my turbo kit.
I have relocation brackets, a spohn torque arm, and spohn LCAs with spherical rod ends.
Basically, im wanting the car to transfer the weight as best as possible.
What would be good shocks without breaking the bank? The QA1's are a little $$ for my taste, perhaps a lakewood shock?
Old Jul 20, 2008 | 02:37 PM
The only shocks I've seen used on the low 60-ft F-Bodys are the QA1's and the Afco's. Neither of them are cheap.
Old Jul 21, 2008 | 11:39 AM
slomarao's Avatar
Summit sells some 3 way adjustables that are 28.00 each. A few guys posting in the drag racing section rant and rave about them. Tom Cowle who has the bolt on record uses them.
Search summit drag shocks and find our app. Than find some v6 springs and your on your way to a cheap fix.
Old Jul 21, 2008 | 12:42 PM
reamo04's Avatar
actually, forgot to mention i already have the summit rear shocks haha.
Im in need of some decent front shocks now.
It just feels like my car just doesnt transfer that good, but maybe it does and i just do not think it does.
Old Jul 21, 2008 | 05:03 PM
I'd be a bit suspicious of a $28 coil-over front shock.
Old Jul 21, 2008 | 05:24 PM
slomarao's Avatar
Glad you mentioned it earlier.
Ya the price has me thinking
As for the front shocks, your going to have to drop some coin to get what you want.
95chwagon
Oct 16, 2015 12:24 PM
NewsBot
Sep 14, 2015 09:20 AM
MDZ28
Sep 7, 2015 09:16 PM
WPHIG2
Aug 27, 2015 06:37 AM
karpetcm
Aug 14, 2015 03:02 PM
