Need help badly.
Old Apr 23, 2006 | 11:11 PM
fesgali's Avatar
Need help badly.
The car starts fine but after the initial "warm up stage" where the idle is at 1k rpm, it'll drop to 600-700 and start running really really bad. Some smoke, almost turns off.
But, if i press the brakes or pump the brakes the rpm goes back up and it starts to idle like their is no problem for a few seconds then it goes back to crap.
I think it might be a vacum leak somewhere and i was gonna start with the EGR. Anyone got some advice?
1995 stock motor lt1 a4
Old Apr 24, 2006 | 05:05 AM
wdtiger's Avatar
Re: Need help badly.
Just start poking your ear around and listen for a whistling or sucking sound.
Old Apr 24, 2006 | 06:38 AM
95LT1conv's Avatar
definite vacuum leak somewhere
Old Apr 24, 2006 | 12:50 PM
GhostZ28's Avatar
i had about the same problem with mine a few years ago. I found that i had no vacuum leak, but the voltage to my pcm was about 1V off. itook it out, cleaned off the connectors with alcohol, and after reinstalling it, my voltage was back to normal, and i didnt have a problem with the engine about dying on me
Old Apr 24, 2006 | 02:32 PM
TraceZ's Avatar
I'd check the IAS too, make sure it is working and not fouled up.
Can you scan it and see what the PCM is telling the IAS to do?
Old May 6, 2006 | 07:31 PM
fesgali's Avatar
Can't really hear anything.
How do I check the voltage of the PCM?
Where is teh IAS located?
Old May 7, 2006 | 12:04 PM
600-700rpm would be within the specs for the A4 in neutral. But is that read off the stock tach (100-200 higher than actual) or off a scanner?
Sounds to me more like its running too rich, if it actually smokes under those conditions. Pumping the brakes may be allowing air to enter the vacuum system and leaning the overly rich idle condition.
Jocofire1
Aug 7, 2015 03:16 PM
kmk7110
Jun 20, 2015 05:53 PM
mattszm6
Dec 14, 2014 07:09 AM
lt1powerd
Apr 12, 2004 02:54 PM
Big_Z
3rd Gen / L98 Engine Tech
12
Oct 12, 2003 11:42 PM
