Name of Tool and where to get it?
Old Feb 13, 2008 | 11:38 AM
67camaro02's Avatar
It's the wire removal tool (best way I know how to describe it) you use it to remove wires from a harness. It's a hollow tube that releases the barb allowing you to pull out the wire. The one's I have are too large and I am trying to find the tool I need. I'm removing all the sensors and connectors I don't need/use.
Anybody got the proper name and better yet who makes one or even a part #?
I've been to O'reily Auto zone and advance and they all look at me like I'm crazy.
Old Feb 13, 2008 | 12:10 PM
white97T/A's Avatar
There is also a pick tool available in addition to the "hollow tube" tool, it just depends on the particular connector that you are working on.
Here is a link to one tool kit that is available. I bought this kit and was impressed with the quality of the tools (except for the multi meter)..
http://www.casperselectronics.com/mm...gory_Code=TOOL
Also Snap-On, Mac, OTC also have these types of tools but be prepared to PAY for them.
Old Feb 13, 2008 | 12:11 PM
miekZ28's Avatar
I don't know if they have a more technical name but its called a 'depin tool'. Most connectors come with a plastic pin/depin tool and there are different types depending on how the pin stays in place. It'd probably be easier to find the right tool if you know the part number of the connector.
Old Feb 13, 2008 | 12:16 PM
67camaro02's Avatar
it's the PCM harness for a 94 camaro that I am working on
Old Feb 13, 2008 | 01:18 PM
You might try an electronics supply store or even a hobby shop that sells small brass tubing for hobby construction.
marlar98
Sep 12, 2018 07:18 AM
mlopezart
Sep 8, 2015 12:15 PM
AtlasXVIII
Sep 7, 2015 03:39 PM
Aug 24, 2015 06:41 AM
4586
Aug 22, 2015 01:09 AM
