Mystery oil leak- Where from???
Old Jun 30, 2005 | 09:36 PM
1Z2Z's Avatar
I thought I had blown a PS line at my last autocross as the car suddenly became almost impossible to steer during a run and when I returned to the pits oil was dripping off the front of the engine, sway bar, etc. Put it on the trailer and came home.
It is not PS fluid that is leaking. There is no smell to it, reservior is still full. It is a light clear oil. Does not appear to be motor oil (Mobil 1 in the motor now). Leakage splatter appears to be limited to the passenger side area around the PS pump, AC compressor and idler pulley.
AC system is still under pressure, but I have not run the compressor. Is there other oil in the AC compressor that could have leaked out onto the accessory belt causing it to slip? Belt never squealed like when wet, and no smoke or anything. The manual talks about PAG oil that must be checked / added if compressor is serviced. Is this what is leaking?
Old Jun 30, 2005 | 09:57 PM
OBE1 95Z28's Avatar
Re: Mystery oil leak- Where from???
Yes the AC system has oil in it. I have a slow oil leak from my AC compressor and it's still fully charged and blows cold air.
Old Jun 30, 2005 | 10:11 PM
1Z2Z's Avatar
Well, mine doesn't appear to be too slow.
I have been planning to remove the compressor (used as a track car much more than street these days), I already have the AC delete pulley and belt. Looks like that mod just moved up the list.
Thanks for the help.
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
