my signal lights dont blink!
Old Jul 17, 2004 | 10:42 PM
jaberocs's Avatar
my left signal lights, the front and rear signal lights and the one in the dash, do not blink! whenever i try to signal left, it just lights up and stays lit until i complete the turn or click the signal back. im not sure whether it is a fuse problem or what...can someone help me out? the right signals work fine
Old Jul 18, 2004 | 03:22 AM
93formula's Avatar
most likely you got a burnt out bulb.
Old Jul 18, 2004 | 03:56 AM
Zepp's Avatar
I agree. Burnt out bulb(s)
Old Jul 18, 2004 | 10:07 AM
Hyperspeed97z28's Avatar
My 97 does this time from time...
I dont have any burnt out bulbs though...
I was told it is the light sockets, But how does one troubleshoot the bad light socket or sockets ??
Old Jul 18, 2004 | 04:26 PM
Z28barnett's Avatar
Lightbulb Re: my signal lights dont blink!
If you want your lights to blink even with a burned out blub.
Gat an heavy duty blinker relay, or an electronic one. They are used with towing trailers. They do not work off of heat from the current going to the blubs like the stock ones do.
Downside, you can't tell when your blubs are burned out. The blinker on the dash will still work. Only cost 4-5 bucks.
Old Jul 18, 2004 | 06:15 PM
n2ceptor's Avatar
Check Flasher----- Check for corrosion at socket--- Loose Bulb/Wiring at socket--Could be signal switch...
Old Jul 18, 2004 | 10:42 PM
93formula's Avatar
if your bulbs all work it can also be a bad taillight harness, its pretty common problem. my sulotion was to grab a used ls1 tail light harness from ebay for 25 bucks. good luck.
Old Jul 18, 2004 | 10:53 PM
rossmatt06's Avatar
I had the same problem on my 95 z. We fixed it by soldering a ground to the positive terminal of the tail-light. Doesnt sound right at all but it worked! No problems since...
Old Jul 18, 2004 | 10:58 PM
93formula's Avatar
yeah a bad ground on the harness will cause that too. but check yoru bulbs, then the ground, then swap out the harness for a newer ls1 one. the sockets in the ls1 harness is much better.
Old Jul 19, 2004 | 12:23 AM
wayfastwhitey's Avatar
I had the same problem with my 94 Z and it was the light socket.
Old Jul 19, 2004 | 10:16 AM
Camerone222's Avatar
When I was installing my clear corners I had the same problem on one side. Turns out the bulbs that are made to go in only one way can easily be put in two ways so all I did was take it out and turn it 180* and it worked great. I'm not sure how recently you have replaced the bulb, but it could be the case.
Cameron
stangspank
Nov 13, 2015 01:02 PM
timmy39120
May 8, 2015 11:41 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
taner
Jul 29, 2002 03:50 PM
