Multiple temp sensors?
I have been working on a heating problem and noticed my 94 is running cold. In addition both cooling fans are coming on when the engine is cold, and the A/C is off. The temp gauge only reads around 175 at best. I changed the thermostat and tried flushing the heater hoses, but still no heat. I know there is a temp gage sensor on the side of engine, is there another one ? where would it be, I cant think of another reason for the fans to turn on. I pulled the individual relays to turn the fans off, and left the last one, i believe is controlled by the temp gauge sensor.
No over heating, the check engine light does come on, I believe thats why the fans are on, Thanks ! I will have it scanned, I still dont have any heat. I pulled the heater hoses and flushed them, I have a steady stream in and out of the Heater Core. The engine according to the gauge is running cool. I pulled the fan relays and the guage went to normal temp around 180 or so. Do you think I may have a clog in the water pump ?
brian:
You might want to add a "signature" showing basic info about your car, including year, model, engine, trans and any major mods. Without knowing that info, everyone has to guess what engine/cooling system you are talking about. You indicated in the post that it is a 94.... but is it a V6 or a V8? That might affect the answer.
