Melling oil pump M-155 w/stock pick up???
Re: Melling oil pump M-155 w/stock pick up???
Ok I knew about the different pickup tube diameter size but the part the tube goes in can be unbolted from the pump, right?
So thats my question can you unbolt the stock piece w/pickup tube attached and just put it on the Melling pump? Or are the two pumps (stock vs. Melling) actually machined different to where that piece that unbolts is not compatable. Thanks.
Rob
Rob
Rob
Rob
So it can be done huh.......I have the gm white spring also so next question is how will the pump perform.
A. Pump will perform at the stock level (melling pump w/stock pickup and gm spring)
B. Pump will perform above stock level (melling pump w/stock pickup and gm spring)
C. Pump will perform below stock level (melling pump w/stock pickup and gm spring)
Originally Posted by tanker
Yes, it can be unbolted, and besides a spring there is nothing mechanical in that piece. If you asked me this question 1.5 month ago, I could have tested it for you .
Pickups of the same inlet diameter should have no effect on performance, IMO. The white spring should increase the pressure a little. That and the clearance on your bearings will determine what kind of pressure you will see.
