Mechanical or Electronic guages?
Old Aug 27, 2007 | 08:41 AM
85305Z's Avatar
so im gettin all Auto-meter guages for the third gen and i noticed that alot, if not all, of them come in either mechanical or electrical. now the electrical ones are alot more expensive, like 65 for a mechanical or 180 for electronic.
my question is, is the electronic one really worth the extra coin?
thanks alot!
Old Aug 27, 2007 | 09:05 AM
Moshbmx1's Avatar
What gauges? Where are you mounting them at?
Old Aug 27, 2007 | 09:39 AM
85305Z's Avatar
im doing the eintire guage cluster plus some extra ones, so speedo, tach, fuel level, volts, oil pres., fuel pres., nitrous pres., Water temp, Trans temp, A/F ratio
Old Aug 27, 2007 | 11:24 AM
Projectz28's Avatar
Moderator
the olny one that is drastically different in price is the fuel pressure. All of the rest are pretty close in price. Yes they are more but IMO the electronic guages are easier to read and less of a mess. No hoses and tubing running all over the place. Much cleaner to run wires and make a harness and put them in loom. You wont even notice it when you open the hood. Here is a vid with mine in it. Never mind the tach... it was not hooked up yet. I did not use a speedo. Its a track only car.
http://videos.camaroz28.com/video/ec...6e01825771.htm
Old Aug 27, 2007 | 11:49 AM
85305Z's Avatar
ok cool thanks
i cant watch vids at work, but ill check it out later
Old Aug 27, 2007 | 03:03 PM
Rice Killer87's Avatar
Sounds nasty!
Old Aug 27, 2007 | 03:44 PM
seawolf06's Avatar
Mechanical gauges are supposed to be slightly more accurate, but not necessary unless you're racing pro street or something. Like he said, the electrical ones are much easier and cleaner and you don't have any fluids in your car.
Brian, that is a sweet ride!
Old Aug 27, 2007 | 05:24 PM
Projectz28's Avatar
Moderator
Originally Posted by Rice Killer87
Sounds nasty!
Thanks, its got a hella big solid roller in it. I think it sounds good to
Thanks again.. I went with electric guages for just that reason. You dont see anything in my engine compartment. I hid all the eiring in factory loom and it blends right into the factory wiring. Unless your looking for it you dont even notice it
With the guages of today, electric guages are more accurate than mechanical, easier to install and you dont have fluids inside the car.
Old Aug 27, 2007 | 08:31 PM
Moshbmx1's Avatar
The only one that i got that was mechainical was N20 pressure becasue i already had a line running in the car so it wasnt hard. For fuel pressure you definately want electrical as the mechaincal ones you need a isolator and from what i hear they dont work that well. IMO as well as most of the other people who posted go with electrical
Old Aug 28, 2007 | 09:09 AM
85305Z's Avatar
thanks again guys!
Old Aug 28, 2007 | 09:27 AM
Mr. Wolf's Avatar
i have a question on this subject also, i've got an 87 z28 carbed and eversince i bought her about 3 years ago the fuel gauge bounces around when the motors running. Whats the best fix?
Old Aug 28, 2007 | 05:09 PM
Are you talking about your fuel tank level gauge, or do you have an aftermarket fuel pressure gauge?
Old Aug 28, 2007 | 09:19 PM
Mr. Wolf's Avatar
level gauge
Old Aug 29, 2007 | 07:56 AM
4THGEN Z's Avatar
The main reason I like mechanical is that I prefer the full sweep look over the 90 deg sweep of most electric gauges....there are some full sweep electric but not many.
I have one of each in my Z in the cassette holder:
Old Aug 29, 2007 | 09:21 AM
level gauge
You've got to track down whether its a loose wire on the gauge end, a loose wire at the fuel tank end, or a failing float. Not really related to the topic at hand
I run Auto Meter Sport Comp gauges:
-2-5/8" fuel pressure, electronic
-2-5/8" oil pressure, mechanical
-2-5/8" nitrous pressure, mechanical
-2-1/16" oil temperature, electronic
-2-1/16" trans temperature, electronic
http://www.injuneer.com/images/photos/DCP04239a.jpg
http://www.injuneer.com/images/photo.../DCP03464a.jpg
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
