Manual Fan Switch Install
I ordered a manual fan switch kit from eBay last week and it finally came in. I'm impressed, it looks pretty nice, but it'll look even better once I get it installed into my car.
So here's the deal, I have to use the power wire from the cigarette lighter as a power source for the LEDs and all that jazz, but.. by golly I can't get to the part of the center console where the cigarette lighter sits. I took the dash apart, and it seems like the whole center console is one giant piece.
I just need to get behind it and splice it in. I have a hayne's manual but it doesn't have the entire dash disassembly process, so any suggestions or easier ways to wire this bad boy up, please let me know.
Thanks,
-Joe Blaze
jblazina@ufl.edu
Thanks,
-Joe Blaze
jblazina@ufl.edu
Re: Manual Fan Switch Install
LOL, I probably bought the same part. The centre console on my 96 Z28 had 2 bolts in the glove box, one bolt under the ash tray, and one bolt in the back of the "CD tray"...I guess that's what you call it. Any who, there was a double sided piece of tape with a foam insert holding together the so called "CD tray" to the bottom of where your radio is. I nearly out of frustration wanted to break out the crow bar for that. Once you've released everything it's just a matter of lifting the whole piece over your shifter and yada yada. Hope that helps.
If you just need to get to the cigarette lighter wires, then you don't need to take the whole console out. The upper portion of the console detaches (the part where your shifter is). If you open up the console door, you will see two latches just in front of the console bin. Push these forward and pull up and the upper portion should come out. From there, if you can't get to the cigarette lighter, you will need to detach the shifter and take the upper console completely off. For a manual, unscrew the shift ball and slide off. For an auto, take out the retaining staple on the front of the shifting handle, and pull up, then slide out the upper console.
Hope that helps.
Jonota
Hope that helps.
Jonota
Thanks,
-Joe Blaze
jblazina@ufl.edu
Thanks,
-Joe Blaze
jblazina@ufl.edu
Originally Posted by nonamez28
ok well i have this on my car, and what is the advantage?
will someone let me know thanks
(sorry im new to z28)
Jul 4, 2005 05:00 PM
slothgrant
Aug 22, 2002 03:01 PM
