manual fan switch
Originally posted by JoeliusZ28
depends where you connect the power source... if you wire it to a constant power source, the fans will stay on without the eng. Wire it to an accessory source that shuts off with the car and it wont.
There are several different methods to wire up a fan switch. It depends on which one you use as to whether you can turn them on any time you want.
As simple as it gets:
Car is off:
Bat to switch to fan wires = on
Relay wires to switch to ground = off
I don't like the direct power source way though. You need a heavy duty switch and a minimum of 14 gauge wire to avoid burning stuff. I tried it for a while till I noticed some smoke coming up from the dash
Car is off:
the SLP fan switch will alow you to run the fans with the car off...
on low you can barely even hear it....and is easily left on
and it will drain the battery quick...beleive me
but it's nice to get the car cool at the track
Originally posted by shoebox
If you tap into the green and blue relay wires for your fan switch, you are using a ground to turn the fans on. Therefore choice of power source has nothing to do with it.
Yeah I don't know if I'm the best guy to take advice from, my fans never seem to work right anyways... they do however still turn on by command from the pcm, thanks to a pesky ses light that came out of nowhere and then disappeared again. Just relating my experiences.
I acknowledge the fact that youre never wrong, but I tested this from the interior before I made the connections by holding it to the cigarrette lighter power source [with just my fingers] and then the accessory power source... and thats how it worked for me. One stayed on, one didnt.
I wouldn't even say I am never wrong.
u must be just talking about the LEDs. i have the LED setup and i only had to tap into the power for the LEDs. in the wiring system where you tap into the blue and green wires from the pcm the fans can only be on when the car is on or the key is turned all the way forward to KOEO (Key On Engine Off) position. the LEDs however will stay on constantly when the car is oof because they are hooked up to a constant power source.
carguyshu
Jan 22, 2017 11:19 AM
slothgrant
Aug 22, 2002 03:01 PM
