lt4 hot cam help ..
Old Oct 8, 2017 | 05:23 PM
Lilo Tapia's Avatar
lt4 hot cam help ..
i just bought a lt4 hot cam only and 1.6 rockers for my lt1 can i just install them right in of do i need supporting mods ? would all my oem parts be okay with this set up.?
Old Oct 8, 2017 | 06:03 PM
Re: lt4 hot cam help ..
What year is your LT1? Dowel pin length will need to be changed on a 93 or 94. Good idea to upgrade the springs and retainers/locks. Lifters might be a good idea if the engine has high miles.
As far as supporting mods, larger throttle body, mid- or full-length headers, 3” catback, cold air intake, PCM tune.
Manual or auto trans? High stall converter with the auto will help.
https://www.camaroz28.com/forums/lt1...nature-879835/
Old Oct 8, 2017 | 06:23 PM
Lilo Tapia's Avatar
It's a 97 m6 z28.
As far as the cam will I need to upgrade anything besides the rocker arms to make this set up work ? Thank you for the respond
Old Oct 8, 2017 | 07:16 PM
Originally Posted by Injuneer
...... Good idea to upgrade the springs and retainers/locks. Lifters might be a good idea if the engine has high miles...... PCM tune.
Originally Posted by Lilo Tapia
It's a 97 m6 z28.
Are those “narrow body" rockers? LT1 centerbolt covers require them. Valve cover centerbolt support tabs will also need to be trimmed.
Old Nov 9, 2017 | 02:40 AM
mrmint69's Avatar
Are you doing the job yourself? I wouldn't recommend it unless you have a lot of experience doing this sort of thing. Like mentioned earlier, there are things that need to be done and correctly. I thought years ago, people were mentioning better options than the LT4 cam, but if you have all the right parts for the right price, it might not be to bad.
Old Nov 9, 2017 | 08:12 AM
He signed out after his last post above, and never signed in again.
