lt4 hot cam help ..
Re: lt4 hot cam help ..
What year is your LT1? Dowel pin length will need to be changed on a 93 or 94. Good idea to upgrade the springs and retainers/locks. Lifters might be a good idea if the engine has high miles.
As far as supporting mods, larger throttle body, mid- or full-length headers, 3” catback, cold air intake, PCM tune.
Manual or auto trans? High stall converter with the auto will help.
https://www.camaroz28.com/forums/lt1...nature-879835/
Are you doing the job yourself? I wouldn't recommend it unless you have a lot of experience doing this sort of thing. Like mentioned earlier, there are things that need to be done and correctly. I thought years ago, people were mentioning better options than the LT4 cam, but if you have all the right parts for the right price, it might not be to bad.
