lt1 ram air converson part numbers needed
i have the hood and air box. i just need to know were i can get the bellow peice (the peice between the maf and throttle body) and a maf wire extender, ive seen the extenders before but cant seem to find them again. i really dont wanna cut my wires.
thanks
thanks
Re: lt1 ram air converson part numbers needed
Best bet for the part from the MAF to TB is just a Fernco Pipe Coupler, 3" to 3" available at any Home Depot. Heat it in boiling water to soften it, then just slip it over both parts.
I'll sell you my old "bellows"..... its been replaced with the Fernco ($5 with the two clamps).
http://cjcfo.fbody.com/members/injun.../DCP04252a.jpg
I'll also look to see if I still have the MAF sensor extension.... as you can see from the photo, I didn't need it.
There is also a molded hose that runs from the airbox to the AIR pump. Are you interested in that?
You will need a rubber insert where the MAF pushes into the airbox, if I recall correctly.
originally posted by SC1twntrbo:
oh and i also need to know the best place to get the grills for the hood
RKSport.com has grille inserts for the aftermarket SS hoods
Polished hood grille insert
oh duh!
97 Trans Am withan SS hood, that would look REAL cool
sorry
but LMperformance.com sells a Trans Am ram air hood that comes with grilles, so somewhere you must be able to buy just the grilles. . . maybe. . . you'd think
sorrybut LMperformance.com sells a Trans Am ram air hood that comes with grilles, so somewhere you must be able to buy just the grilles. . . maybe. . . you'd think
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
CobraEatr
Jul 22, 2002 09:49 AM
