Low Coolant Sensor???
Old May 31, 2006 | 04:09 PM
LPE_wannabe's Avatar
My low coolant sensor light is coming on at random times all of a sudden...has anybdy else had this sensor ever go out on them?
Old May 31, 2006 | 04:13 PM
MyShibbyZ28's Avatar
Re: Low Coolant Sensor???
Mine went out on me. Not hard to replace. Just need to drain the coolant to the level of the sensor, pull it out, replace, fill coolant back up.
Old May 31, 2006 | 04:32 PM
it's about 2 inches under your radiator cap on the engine side...i just didn't wanna pay $50 if it was some sorta wiring problem or something...thanks
Old May 31, 2006 | 04:51 PM
2001NBMZ28's Avatar
Just disconnect it, tie it off and the light won't come on. My car doesn't even have one.
Old May 31, 2006 | 07:23 PM
OBE1 95Z28's Avatar
Always verify that your radiator is full before you assume that your sensor is bad. The sensor is a common failure, but coolant leaks are common too.
Old May 31, 2006 | 07:28 PM
Donohue96M6Z28's Avatar
i did this same thing, they've went out on all 3 z28's that i've owned.
Old May 31, 2006 | 11:43 PM
yeah my radiator's full up and i'm pretty sure the overflow is good to, but then again, that thing is kinda hard to read
Old May 31, 2006 | 11:52 PM
Originally Posted by Taintedz28
the radiator in ym car is full but the reseve tank isnt. it always gets low, but when i put more in it, it spray back out. does that mean I need a enw radiator cap?
i just watched a few of your videos. I was 16 when i got my 1st z28 too, trust me, you might want to not rag on it as much as you do. you're asking for problems, that car will not last forever with the bull**** you put it through, especially with 100K+ on it, things are going to start breaking before you know it and you will wish that you had not mistreated it like you've been doing in those vids. just my .02.
Old Jun 1, 2006 | 01:47 AM
urbaNHunter44's Avatar
What do you mean, "tie it off?" Just connect the wires together and tape them up? Or just un plug it?
Old Jun 1, 2006 | 02:20 AM
just unplug it and then tape or tie it out of the way
Old Jun 1, 2006 | 10:36 AM
96 Z 28's Avatar
Yup, this sensor is strictly for low coolant light. No SES Light or any other problems will arise from unplugging it. They are famous for going bad.. Mine has been unplugged for 3 years now...
Make sure to check your coolant Level on a regular basis though.
Old Jun 1, 2006 | 10:14 PM
OBE1 95Z28's Avatar
If you're loosing fluid out the overflow tank, you need to find out why. On a hot day the car while need to use the overflow tank; if it's loosing fluid you'll end up with a low radiator condition.
Old Jun 2, 2006 | 01:08 PM
grandnational007's Avatar
check shoebox's site, he has a pic of it's location and everything else you need to know
Old Jun 2, 2006 | 01:31 PM
6SpdLT1Z's Avatar
IIRC when the engine gets hot it sucks coolant out of the overfow tank and when it cools off it gets back in. If you put extra in it will boil out the resivour tank. I'd go ahead and verify your tstat is working correctly and replace the radiator cap. (it's like $10 at GM)
Old Jun 2, 2006 | 02:52 PM
OBE1 95Z28's Avatar
Got this backwards, when the engine gets hot the pressure in the engine coolant system rises causing overflow to route to the reservoir tank. As the engine cools the system sucks the fluid out of the reservoir back to the radiator. Just look at the coolant dipstick, the hot mark is higher than the cold mark.
