Low Coolant Sensor???
Re: Low Coolant Sensor???
Originally Posted by 2001NBMZ28
Just disconnect it, tie it off and the light won't come on. My car doesn't even have one.
Originally Posted by Taintedz28
the radiator in ym car is full but the reseve tank isnt. it always gets low, but when i put more in it, it spray back out. does that mean I need a enw radiator cap?
Originally Posted by urbaNHunter44
What do you mean, "tie it off?" Just connect the wires together and tape them up? Or just un plug it?
Yup, this sensor is strictly for low coolant light. No SES Light or any other problems will arise from unplugging it. They are famous for going bad.. Mine has been unplugged for 3 years now...
Make sure to check your coolant Level on a regular basis though.
IIRC when the engine gets hot it sucks coolant out of the overfow tank and when it cools off it gets back in. If you put extra in it will boil out the resivour tank. I'd go ahead and verify your tstat is working correctly and replace the radiator cap. (it's like $10 at GM)
