Low coolant light still on.
Old Mar 27, 2015 | 03:39 AM
zxtce's Avatar
Ive searched and cant find a solution to getting the light to go off even after I unplug it on the radiator. Do I need to unplug the RAP module for a few seconds or what? Thanks in advance. This is on a 94 z28.
Old Mar 27, 2015 | 08:19 AM
Re: Low coolant light still on.
Did you check the level sensor harness wires to make sure they are not shorted together?
Old Mar 27, 2015 | 03:19 PM
zxtce's Avatar
Not shorted on the plug, but somewhere down the harness they could probably be shorted I guess.
Old Mar 27, 2015 | 03:25 PM
zxtce's Avatar
Would there be any other reason for the light to stay on?
Old Mar 27, 2015 | 06:43 PM
The latching relay is in the RAP module. Haven't heard of that going bad, but I suspect it's possible.
Old Mar 27, 2015 | 07:12 PM
zxtce's Avatar
Thanks, I will probably check that out sometime this weekend.
Old Mar 31, 2015 | 02:04 AM
Fatdog2's Avatar
Is the radiator full?Check it when its cold.Did you change out the fluid recently?
Old Mar 31, 2015 | 02:22 PM
zxtce's Avatar
Radiator is full, I am sure the wires are shorted down the line somewhere, just have to find the time to check them.
Old Mar 31, 2015 | 08:47 PM
GaryDoug's Avatar
Prominent Member
This may help locate the short: Use a multimeter set to continuity with an audible beeper if available. Unplug the connector and connect the meter leads to each wire. Then move along the wire bundles wiggling them until the short becomes intermittent. You can do this without a beeper alarm if you use long leads and keep the meter positioned where you can see the display. Another tool to use instead is a battery-powered test light.
Old Apr 1, 2015 | 01:07 AM
zxtce's Avatar
Thanks for the tip, it will give me something to do this weekend. Again thanks for all the replies.
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
rwferguson43026
Feb 6, 2015 10:06 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
