Low coolant light on, coolant not low!
Like the title says my low coolant light is on but my coolant is fine. I don't overheat and sometimes it turns off by itself. Its a really annoying light on the cluster. If it costs too much to fix i'll just take the bulb out. I don't wanna do that though. Any suggestions?
Re: Low coolant light on, coolant not low!
its most likely the low coolant sensor, i forget the cost to buy a new one, but its cheap. pop out the old, and put in the new. its a really quick fix. its on the radiator, a few inches below the radiator cap if i remember correctly.
exact same problem on my moms 2002 grand prix gtp. GM flaw i guess. Its in the same location too, right under the radiator cap. Some people say u can take out the old one and clean it and it will work again but if u do all that effort to take the old one out might as well replace it...
I have the same problem. I just unplugged the connector for now and the light went out.
Let us know if the cleaning worked!! I got a NAPA parts quote of $63. Cleaning sounds like a better solution, but if it's not effective, then I don't want to invest in false solution.
Info from Shoebox's Tech Pages. Part prices are "plus shipping" and may be a bit out of date, but it does indicate you can get the replacement from the popular online discount GM parts dealers for way less than $63.
1994-1997coolant level sensor (2 way plug) - PN 10096163 - $23.35
1994-95 coolant level sensor (8 way plug) - PN 12135027 - $18.54
